the ls1024 can be prgrammed in place once the system is up and running, its the other ones that require the pre-programming
Kipper2k, thank you for this information (amongst everything else).
That was the last obstacle on building the board. Now just have to buy some parts :D
the tsop flash can be programmed at run time. I dont think the LS1024 can. the JED file is in the archive, so that tells me it needs flashing with a tool
I was told by someone on A1k.org that it can be done so i am relaying nfo i got. Just because the jed file is in the archive doesnt mean that it needs to be per-programmed ?
GB1000order list updated 030 30th May
To calculate shipping go to this page and click on the link for Canadapost rates
Please check for errors and omissions.
All paid shipping orders except for 1 are all mailed or will be mailed today
I'm on orange now! :arms
Probably found the GALs, the LSI1024 (from a German shop, let's see if they ever invoice & ship); got line buffers & Fieldmem for flicker fixer & SuperDenise from the other bay, and donor A500 for CIAs/Gary/Paula/connectors locally from here. Plenty of 4 MBit EPROMs already at home from A3000 project.
Missing Amber, all small-stuff, discr logic and FPU. Probably will search for the flash rom, too.
Anyone know where the contents of the 27256 can be located at? Didn't find that in Braun's archive files.
At the Braun's homepage you can find a version compatible for 68060 but i think that is well also for 68030.
http://www.gb97816.homepage.t-online.de/eprom_atbus.htm
Probably the normal rom 6.10 for at-bus2008 ide or oktapussy can work well.
Thanks, Massimo. It looks like Oktagon ROM is also available at Aminet.
