A4000D not recognizing floppy
Hi
I'm currently rebuilding an A4000D from bits & pieces I got.
Its an 030/25Mhz unit, all capacitors in the PSU & motherboard have been replaced.
It boots fine from HDD, but wont boot from floppy (I do see the drive light up & do a short spin).
On the desktop, it shows as "DF0: ???" no matter if there's a disk in or not.
There is also no "click" sounds from the drive, at all.
I thought the drive is at fault but it behaves the same with another drive which works in my A1200.
Also tried a different floppy cable, same results.
Am I looking at a bad floppy controller? :help:
Any ideas would be greatly appreciated!
