A1200/30@40Mhz vs A4000/30@25Mhz
My adventures continue :D
After finally getting my A4000/30 up & running, I filled the HDD with demos & watched a few.
I have the same demos on my A1200 (1D4 board, GVP A1230+ EC030@40Mhz & 8MB RAM).
I noticed several strange things:
1) Some 3D effects (hard to categorize, but mostly textured objects) run noticeably FASTER on the A4000! 25 > 40 ? :p
2) On the A1200, in lots of demos, there are small "jitters" - movement that should be smooth isnt.
One very bad-looking example is the end-scroller in the demo Atome.
This problem does not appear on the A4000 at all!
Can this be related to timing issues on the 1200? I havent made the timing-fix mod since I was sure it only affected 040/060 accelerators.
Btw, both machines have an FPU, but I doubt the demos in question actually use it.
