Yup, having a major spring clean this year, and decided I have a few things just getting in the way. Feeling generous and decided to give 'em anyway so if anybody wants anything let me know.
Collection preferred (especially for bigger items) but can deliver if postage costs are covered.
Remaining :-
5 - Citizen swift 9 dot matrix printer. Seems to work fine when trying inbuilt test prints - although ribbon cartridge is a bit dried out. In original box with manuals & complete with print manager for the Amiga.
Taken so far :-
1 - Miktronic A4000 full size tower case. Used to rehouse a standard A4KD. Just the case (no busboard) but would be easy to convert to use a mediator board. Has most (if not all) of the fittings but would need a little wiring work to hook up a psu. Ideal for a project. - Taken, Posted.
2 - 8 x 30pin memory simms. Not sure if these are 1mb or 4mb, but should be ideal for any older memory expansions. Untested. - Taken, Posted.
3 - 8 x Goldstar chips, labelled GM71C4256A-70. Believe these were actually cache ram chips from an old pc board, but should work in A500 memory expansions? Untested. - Taken, Posted.
4 - Xcopy professional original disk with "cyclone" hardware. - Taken, Posted.
6 - Multiface 3 zorro card, with disk and manual. Worked fine when last used, but that was a few years ago now. Taken, Posted.
7 - 3dfx voodoo 5500 (?) pci gfx card - the one with the twin chips. Seems to work when a quick test was done in a pc. - Taken, Posted.
8 - 3dfx voodoo 2000 (or 3000?) pci gfx card. Used it a couple of years back on a mediator board. - Taken, Posted.
9 - Catweasel Z2 & buddha zorro board. This is a non flash version of the Zorro Buddha ide controller board with a stock catweasel card installed on it. In theory you could use the later on any amiga. With manuals, drivers disks etc. - Taken, Posted.
10 - Clarity 16, external 16 bit sound sampler/player that connects via the parallel port. Also has midi ports. Boxed with all disk and manuals. - Taken, Posted.
and non amiga related - 2 x 12MB voodoo2 3d pci add on cards for pc. (The original SLI setup!) - maybe of use for some retro pc gaming? - Taken, Posted.
I have an original Voodoo 1 as well, and a PowerVR board. - Taken, Posted.
Items have been stored in anti static bags etc, and in generally good condition. Pics available on request.
...about it for now, but probably more later. :D
(Update : Updated with current status again.)
(Update 2 : Re-arranged to make it clearer which items are remaining).
