Hi kipper, I've left feedback for my purchase :)
Payment sent for 1 x cdtv 8mb ide card + adapter.
Good News
Received mine today, memory works OK.
Bad News
I can't get the CF Ide working. With no card inserted the led is lit all the time. With a card inserted no led activity at all. Doesn't show on workbench or in HDToolbox.
Am I supposed to connect the 2 wires to the MB?
EDIT: Well it just goes from bad to worse, now the led stays lit all the time card in/card out and the CDTV wont boot with the board connected. Time to E-mail Kipper I think.
Hi Kipper2K
I would like one of these 8MB fastmem board with IDE for my CDTV with the appropriate adapter (if required)
To use the Ide on the CDTV I need to connect to int2 and ovr. According to the ide68k site int2 in on the CIA chip. Anyone know where the ovr connection can be found?
EDIT: Is OVR pin 29 of the Gary chip?
Is INT2 pin 21 of CIA (U9)?
Yes, like this:
http://kipper2k.com/amigaforsale/boardmounted.jpg
http://www.l8r.net/technical/cdtv-technical.html
http://www.ianstedman.co.uk/Amiga/sc...chematics.html
Diagnostic Slot:
This slot is the equivalent of the side expansion slot of the A500, and includes most signals necessary for serious expansion. This slot is located inside the CDTV, on the right side of the motherboard, and uses a unique 80 pin connector available from KEL.
The connectors that mate with the CDTV motherboard connector are are 8801-080-170S (preferred), 8800-080-170S, or 8802-080-170S. Last time I checked, small quantities (~100) are available in the U.S. from Lo Dan West, (415)592-4600 or 1-800-541-1001.
Connector:
1=GND 2=GND 3=VCC 4=VCC 5=/CFGOUT(#)6=/CFGIN(#)
7=GND 8=/CCKQ 9=CDAC 10=/CCK
11=/OVR
12=XRDY
13=/INT2
14=nc 15=A5 16=/INT6 17=A6 18=A4
19=GND 20=A3 21=A2 22=A7 23=A1 24=A8
25=/FC0 26=A9 27=/FC1 28=A10 29=/FC2 30=A11
31=GND 32=A12 33=A13 34=/IPL0 35=A14 36=/IPL1
37=A15 38=/IPL2 39=A16 40=/BERR 41=A17 42=/VPA
43=GND 44=E 45=/VMA 46=A18 47=/RST 48=A19
49=/HLT 50=A20 51=A22 52=A21 53=A23 54=/BR
55=GND 56=/BGACK 57=D15 58=/BG 59=D14 60=/DTACK
61=D13 62=R/W 63=D12 64=/LDS 65=D11 66=/UDS
67=GND 68=/AS 69=D0 70=D10 71=D1 72=D9
73=D2 74=D8 75=D3 76=D7 77=D4 78=D6
79=GND 80=D5
Pins 7 to 80 on the Diagnostic Port are the same as pins 13 to 86 on the 86 pin connector of an A500.
Thanks for that Kipper, makes connecting a little easier.
EDIT: Guess what fits the diagnostic slot a treat......80 pin SCSI connectors.
