Originally Posted by
demolition
Item received today, and seems to be working fine. Just installed it in my 500+. All 2+8MB RAM is present and it boots from the CF card. It is currently running mem tests, but after 20 minutes there's still no issues, so it is probably good. :)
I do get a PFS3 popup requester with some error when it mounts the CF partitions, but they do show up in WB and seem to work so I probably just need to repartition the card since the image I wrote onto it was from some other CF card.
Will leave feedback.
Edit: Feedback done. 1˝ hours in, the memtest is still going strong, so still looking good. :)
Edit2: Just tested the AR MKIII in the 500+ with this board installed.. Not a good idea. Various colors appeared on screen and the floppy drive made a horrible noise. After this, the floppy drive wasn't working anymore. Turns out the head had gone off the spindle and couldn't be pulled back by itself. Pushing it physically back onto the tracks fixed the drive and it's working fine again. Lesson: AR does not like this board, or maybe even any uncommon memory expansion.. Consider yourself warned. :)
