Originally Posted by
kipper2k
Yellow screen, black screen, and also the Amiga fault screen is an indication of bad connection of the CPU to motherboard, normally it is the right hand side pins of the CPU that cause the issue due to the Caps that may be higher on one motherboard than another, try removing the adapter, and use the socket from that on the bottom of the fastmem board and plug that into the motherboard and see what happens, also check the solder joints of the CPU socket on both the adapter board and the fastmem board to see if they are solid, check pins as well, make sure none broke/missing, if you can't get it going, no worries, send it back and i will replace it. Also try without using the 2 pin wire connected and see if the computer boots and RAM visible
@Xianti,
Take a picture of the board installed so i can see your wire connections
I'm away from home till Wednesday so i will look after new requests then
