If it works With ks1.3 nyt not With ks3.1 it might be A500 motherboard revision issue. Some early models requires jump wires to use With ks3.1
Declaring interest in one 8MB board. I do also want to buy some of your other items you have on your web page.
Should I just send you a PM with the list and then get an okay from you to make a payment ?
// Johan W
Thanks Kipper, packaged arrived safe and sound last week. Yet to test due to eprom 27c800 and Willem issues. That'll teach me to buy a cheapo programmer.
Hi, just a quick question on the mem board installation: Is the expansion slot still usable with the 2 pin header in place, let's say for an Impact Series II expansion?
Finally able to do some more tests!
Ic strips in place
Attachment 71989
CPU board in place
Attachment 71990
Side view of men board
Attachment 71991
No go after power on, yellow screen
Attachment 71992
I got a couple more strips and tried without the CPU board and no luck
Attachment 71993
Attachment 71994
Also tested with another Amiga, same revision 6a and no joy :(
do you have a KS 2.05 to try it with? I had issues with 1.3 + trapdoor RAM. As soon as I changed to 2.05 it played OK with the trapdoor RAM.
I would like to order one of the 8MB boards at the earliest convenience please!
[my lonely A500 needs a HDD to keep it company]
I have also emailed @kipper2k...since this thread is rather long now...
I am interested in A500 8MB FastMem Board with CF IDE and A500 CPU Adapter. I have 500+ with 2,05 37.300 ROM. 2 MB Chip. I am also interested in additional set of risers for use with Indivision.
To follow up with my A1000 issues. I can confirm that both boards work in a Revision A motherboard but boot to yellow screen on Revision 6 motherboards. It was mentioned that some A500s require additional soldering and I am wondering if Rev 6 A1000 motherboards may require the same thing.
