Quote:
Originally Posted by
xianti
xianti
I think I must have broken your board ( static?) as it now doesn't work with either ks version. Grey for 1.3 And yellow for 3.1 . I'll take some pictures tonight however and post them anyway ...
Finally able to do some more tests!
I got a couple more strips and tried without the CPU board and no luck
Also tested with another Amiga, same revision 6a and no joy :(
I got a rev6a motherboard from Amigakit late last year so popped out the original rev5 board my A500 was born with. I sorted out my eprom burning issues by borrowing a professional programmer
from a workmate. Next wired up switches to switch between 1.3/3.1 and 1mB chipram and 512k chip/512k slow.
Had forgotten how to load classic workbench after more than 6 months so rewatched all the Youtube clips, etc.
The point is that initially all was working fine, albeit with the odd crash or error. There were 2 things I wasn't happy with, there is a capacitor that "will" short out on the CF IDE chip socket pins if not insulated, and the other
thing was that my new mobo had green corrosion on cpu socket pins 63 and 64. Initially I just put some electrical tape on the capacitor but realised that the 8mb ide board was not sitting straight. So I removed the pcb
and extended the capacitor pins to bend it out of the way. Would have been easier to just put a new cap there I guess.
At the same time I cleaned the corrosion off the cpu socket pins. Upon turning the Amiga on all I got was a black screen, by then it was nearly midnight so went to bed a bit peeved.
It turned out that after cleaning the corrosion off the socket pins the 32pin header supplied with the 8mb ide card wasn't making good contact. I proved this by inserting a spare 68000 cpu into the
header and turned the computer on to a black screen. Then I removed the header and inserted the cpu into the original mobo socket, all good and working.
I had to bend out the spring part of pins 63 and 64 on the socket so the 32pin round pins would make proper contact.
My Amiga is now working heaps better without the crashing and errors I was getting before. As Kipper has mentioned most problems are likely being caused by poor connections at the cpu socket.
I believe in electronics that if You mess with something and afterwards it doesn't work, it's probably not just a coincidence.
http://i57.tinypic.com/10zsape.jpg
http://i61.tinypic.com/r06mvl.jpg
http://i57.tinypic.com/2qv76o0.jpg
http://i60.tinypic.com/5360sk.jpg
http://i58.tinypic.com/2mhhs20.jpg
