Problems with a SCSI chain in CyberStorm PPC
What I've tested:
Tested with various adapters, and two different SCSI cables.
Tested the RAM:
Chip + Fast with: sysdiag-0.1.4 - Result: All tests pass.
PPC Mem with: PPC-Memtest - Result: All tests pass.
Term power on and off on the HD
Term on/off on the CD ROM
FastSCSI-II adapter with and without high bits term.
I've also tried with lots of different Masks and Max Transfers. Mask seems to make little difference, but the lower the Max Transfer, the more data it can move before it crashes.
How the devices are configured:
The Harddrive, Seagate Barracuda ST318437LW is set to device id 1. No other jumpers are set.
Regarding TE on J2 on my HD, the manual states:
Quote:
TE (Applies only to the N and W models)
On With the jumper installed, the onboard (non-removable) terminator circuits are enabled (connected
to the I/O lines). Default is jumper installed.
Off Terminator circuits not enabled (not connected to I/O lines).
Since my model is LW, and not N or W. Then I assume that this doesn't matter for my drive.
My CD Rom is set as id 5. No term is set on it. It's a Plextor Ultra Write 40x.
The chain:
Code:
# A #--# CD #--# HD #--# CS #--# A #
Legend:
A = Active wide terminator
CD = 50 pin (Fast SCSI-II) CDROM
HD = 68 pin Wide SCSI Harddrive
CS = CyberStorm PPC
MODS:
I suggest that you close this thread. And move these posts to the HD crash thread. So can Kin and I continue there.
Please split out, and merge this thread from post #4 (above) to this thread: "Huge file operations end in DH0 crashed"
Thanks, and thank you Kin! I trust you when you say it's not overclocking.
