The ACA500 Compatibility Thread
Hi Guys,
I thought I'd start this thread so we can share what types of CF Cards and Turbo/Ram boards we have tested with the new ACA500 so we can build a compatibility list for the community.
So I have tested the following Accelerators:
ACA1220 (overclocked to 26mhz) = Working perfect as expected
ACA1232/33 = Working perfect as expected
Both the above are officially supported of course but ACA1220's sold before 5th September 2013 will need a Firmware fix before you can use them with the ACA500, contact Jens at icomp.de as he will do this at the same time if you pre order the ACA500 direct.
If you bought your ACA1220 after 5th Sept 2013 it should have the fix already but please check with your reseller.
I have also tested the following CF cards:
4gb Sandisk Ultra 30mb/sec = Working in AUX Slot / Not tested on Boot Slot
4gb Kingston (flower type) = Not tested on AUX Slot / Working on Boot Slot
4gb Generic/Unbranded CF Card = Working in AUX Slot / Working on Boot Slot
2gb/4gb Transcend 133x = Not tested on AUX Slot / Working on Boot Slot
2gb Verbatim = Not tested on AUX Slot / Not Working on Boot Slot*
*Stops the A500 from even detecting the ACA500
I hope this helps and please feel free to add your own experience and I will create the full list and update as I test further.
