4 Attachment(s)
68060 on ACA500 Amiga 500 & firmware update
As an experiment , i have tried and now have running a Blizzard 68060 on an ACA500 ... Amiga A500!!!!
more testing to do but I'm tired now but here it is, the 3.1 rom selection will not boot the 060 (you get a yellow screen / rainbow crash) but the 1.3 rom will and shows full 68060 and Ram and it boots from floppy....
sysinfo , demos etc later, i'll also try the scsi and 128mb
Specs
Amiga 1.3 512k , 512k OCS Rev5
blizzard 68060
ACA500 2mb fast
Also the 1.3 cannot boot in to 3.1 hard drives , so i'll format a 1.3 setup on a spare CF card and see what happens..
mike
Worlds first??? probably not :-) surely this needs a separate photo booth moment...
http://youtu.be/eNCe1KsLcO4
Blizzard 1260 nearly fully working!
I found a solution, it is quite ugly hack but it does work, 68060.library works, FPU works. Sysinfo won't crash anymore and results are slightly faster than previously.
Replace your libs:68060.library with this one: http://www.winuae.net/files/b/ACA500...d1260_Hack.zip
(DO NOT USE if you don't use it with ACA500!)
It is Phase5 68060.library patched to not clear ITT0 and DTT0 registers. (Transparent translation registers that ACA500 uses to mark lower 16M as uncacheable for both data and instruction), these registers have priority over MMU tables.
Note that most likely any debugging program (like enforcer) won't anymore work with chip ram (or any ram inside first 16M), also this hack won't work if any program touches ITT0 or DTT0.
