OK thanks. Can you post better pictures and / or confirm the exact part number of the simm and the RAM chips please.
I'll see what I can do for you :)
---------- Post added at 23:26 ---------- Previous post was at 23:25 ----------
If the PPC is in a A1200 then I'm suggesting to take a dremel or simillar tool and re-shape the bracket if one of the SIMM's is tight up against it. There's quite a bit of leway here for making a small but very handy mod.
I have offered a refund if Amigaman2000 wishes to take me up on it. This same offer goes without question for anyone else who experiences simillar problems.
I have updated post 3 of this thread to reflect the use of a rubber band or zip tie and possible modification(s) if used in a standard A1200 on PPC boards.
Thing is: even when a chip is labelled as 50ns, it may fail running at such speed, hence the manufacturer mark the SIMM as 60ns.
Actually, no. Manufacturers are not permittted to label chips at 50ns if they won't run @ 50ns, period.
What might make a 50ns chip not to run @ the stated 50ns is the hardware it is installed on.
On the other hand, chips labelled 60ns may actually run @ 50ns, but again, this depends on the hardware it is installed on & the quality of the 60ns chip.
*edit*
Sometimetimes, the industry deliberately label 50ns chips as 60ns purely to meet demand. This is also very relevant to all of todays current memory chips, CPU's & GPU's. - If you're lucky enough of course. ;)
I have tested the SIMM modules again and I can confirm that the SIMM doesn´t fit on my Blizzard PPC flat SIMM socket, I have tested on two different Blizzards PPC cards and it doesn´t work in none of the two. It fits and works perfectly on the angle SIMM socket but I must remove the floppy disk drive bracket to fit it.Quote:
So now I have one SIMM on my Blizzard PPC card and the other one in the SCSI module of my Blizzard 1260. :D
Regards
---------- Post added at 21:27 ---------- Previous post was at 21:25 ----------
@ddni
No I received two of then and they are marked with 6 not 5.Quote:
Are the actual RAM SIMMs that you have all marked in the same way.
Regards
All trading on here by me is currently suspended due to the current situation on this website. Hoefully it is only a temporary situation.
Mods, please cose this thread until further noticce.
