ACA620EC freeze/overheating
I just replied to a separate thread regarding a similar issue, so I hope I didn't break any rules by doing so. I figured a new thread specifically for the ACA620EC overheating might be beneficial for viewing and diagnosis.
The problem: I'm experiencing the freezing issues after about two minutes of use on a stock A600 v1.5 board w/ plain WB install.
The test: The machine works fine with the case opened and I've left it running for over an hour without issue...until I closed the case. It then froze after about two minutes.
The culprit: Overheating. This board gets HOT. I mean it. It hurts to touch it.
The questions: How was this able to ship if indeed faulty? Is there anything I can check for? Will another ACA620EC exhibit the same issues? Why is the ACA630 discontinued when it worked so well? Am I out of luck?
I used to be able to run my 630 just fine without issue. I cleaned the pins and checked for shorting or bent pins/etc. Everything is completely fine on the A600. I've read about a few overheating issues about this accelerator, but there isn't any follow-up. Suggestions?
