As my SCSI project seems to be failing miserably, I have turned my thoughts to adding an optical drive to my a1200. Why? because I can......
I amusing an ID-FIX express and will want to run this off the secondary 40 pin channel. I will probably split the floppy connector to power it.
My a1200 is raised due to the angled sim slot on my blizzard 1260, and due to space constraints I want to fit this drive facing forwards and slung under the miggy, on the left hand side.
Ideally what I would really like is a slot loading white/cream bezelled drive with an eject button, along with instructions for what adapter I need to fit on the back to then connect it to the IDE-FIX Express. I am considering whether or not I cannibalise one of those enclosures for drives to provide a case for it, or given that you will basically not see anything but the front bezel, whether I bother.
I could probably even just go for a black slot loader I suppose.
So, rethinking it, a compatible black slot loader slim (laptop type) drive with an eject button.
Any offers? / suggestions?
On a related note, I currently have a feed running directly off the 12v (I think - the top 2 prongs) on the PSU connector, which is powering 4 small fans (2 case, 1 Indy 1 Blizzy). Would I be better pulling the feed for the optical drive off that? It is more conveniently located being honest.
Cheers
C
EDIT - this thread began life as a wanted thread, and although the final result was in fact what I had set out to achieve, there were quite a few mistakes and lessons learnt during the process. It has been suggested that this could serve as a useful thread under AmiOracle which is fine by me - just need a mod to make it happen......
