Originally Posted by
spcbm
Nice PCB, just some comments:
- Try to put arduino USB port near PCB edge, so you can make a hole on the box to connect USB cable. (Have a look at pictures on post #269)
- The datassette connector has solder mask, you used it inverted, this will not affect your prototype, but should be considered for factory production.
- The price is the same for 1 or 2 sides PCB's so you can use 2 layers.
If you put the files on github I can make the changes.
I've been working with a Chinese manufacturer last year (more than 6 differents PCBs) and the price is lower that OSH, while the quality is good. I can make a batch.
Shipping from Spain is cheap if you keep the weight under 100 grams (3.5 oz)
