- I've got the USB port as close to the edge as I can, should be able to make a hole in a case and see it, won't be flush with the side though. The problem is the SD Card connector placement, I've tried some alternatives placings but it usually ends up messier.
- The Datasette connector was confusing... I had to mirror/rotate until it worked, specifically for single bottom layer placement.
- I could use 2 layer, but then I need two different designs for factory fabbed or home made PCBs, I'm trying to keep it to one so anyone can make one. Two sided would be a lot easier tho...
Also:
- I've seen that Nano library part before. I didn't use it for two reasons: firstly it has some incorrectly labelled pins IIRC and secondly I want the Nano to be socketed and there only seem to be 32 way sockets (not 30 way) so I've used that instead.
I have the files in github now, give it a go and see what you can come up with. The files are called Tapuino-with-mux.brd and .sch.
Please keep to single sided for now :) I'll route a two sided board tonight just to see for comparisons sake, maybe we'll just need to have 2 designs.
-(e)
