Just checking as I'm able to obtain a mini-DIN locally and want to be able to also use it in my C16.
So V2 hardware support (basically using pullup based buttons) is in as well as a bug fix for abort which caused the browser to go up a dir.
Big thanks to @kubino for both of these, this is the awesomeness of open source!
-(e)
Interesting that it needed a clean. I'll pm you for details.
Received yesterday the first batch of PCBs.
Assembled the first unit, loaded new software and display is in loop Play-Record-Options, it looks like all the buttons are pressed. If I press all the buttons then stop.
Sweetlilmre, you mentioned some kind of config swith, how to change it?
The V2 hardware revision has the buttons connected to arduino and GND.
Look in the config file. There is "#define KEYS_INPUT_PULLUP" which is commented out. Remove the comments and compile / flash and you should be good.
Cool! The new code in Github has the config switch and a bug fix.
Tested record from C64 to Tapuino OK.
Tested record from Tapuino to datassette OK, for this need to put invert=1
I tried loading from datassette to C64 or tapuino but I think this is not implemented yet?
I will update the pre-sales thread for PCBs, and then need to fit all in the box.
I'll have to check the code, I know the pin setup is in, but there probably needs to be a new menu switch. Off to a wedding so will check tomorrow morning, or more likely afternoon... :-)
