@ozayturay: Have you seen this boxes? They are from Turkey and they have the hole for 1602 LCD (I think). Could be a good option for adding a box with LCD displays:), not for OLED:(
http://www.ebay.com/itm/MDT-65-ABS-P...-/161099909034
Thats what i mounted mine in :D.
Had to opt for a 328 chip because of space tho......Attachment 89663
I have already ordered 4 of those boxes and they alltogether cost less from the one you linked from ebay. ;)
The manufacturer is a Turkish company named AltınKaya Elektronik Cihaz Kutuları and have really good enclosure alternatives for electronics projects.
http://www.altinkaya.com.tr/Duvar_Ti...ar/DT-065.html
Edit: They have a European website too. :)
http://www.altinkaya.eu/desktop-encl...46-dt-065.html
Hi, I noticed board layout has been updated to rev. 1.71 which embed the fix for the buzzer and led circuits
Since I want to send the board to DirtyPCBs manufacturer (for personal use, I will not sell them), I processed the .BRD file wih the DirtyPCBs design rules (.DRU) provided and found five overlapping errors (while board rev. 1.7 gives no errors).Is this important or irrelevant?
I remember some overlapping errors on 1.7 on the datassette edge connector because of the vias to connect both sides. I haven't revised rev.1.71 PCB, can you tell me where the errors are located, I will check ASAP
Is the DT-065 ? You mean there are no room inside for USB Nano and you have to mount the mini?
Just ignore them, the error is because I changed layout for ceramic capacitors, so you can mount capacitors with 2,54 or 5,08 mm Raster and this is the cause of the error, two pins are joined. if you can not aprove the error, just change the capacitor type to one with 2 pins only.
Attachment 89830
I have a Problem with the Software.
tried following Versions of arduino-Software: 1.6.2 / 1.6.3 / 1.6.4
every Version runs in Trouble with compiling tapuino-Software, no idea what i am doing wrong :-(
here is a pic of it...
who will try to teach an idiot how to do it ;-)
