From the pictures on your assembly guide it seems I have the same buzzer of yours
Yes, confirmed, PCB 1.71 R2 is 100% working
Hello, I have a proposal. Tapuino shouldn't finalize a recording when the motor is turned off. It should just wait for either the motor to be started again or the user to press "stop". I'm playing with the Freeload mastering tool. It loads each file from disk and then it stores it on tape. But it doesn't work with Tapuino, because when the program stops the motor and reads from disk, the recording is finalized.
Hmm interesting. Please add an issue to github and I'll look into it
-(e)
I have added this as a feature to the "finalize_option" branch in github.
If you could pull this and test, see if it does what you want it to do?
There is some additional clean-up I'd like to make to the code, but before I go any further I need you to check the functionality.
In a nutshell: New option "Auto Finalize" if this is OFF or ZERO then the recording will continue until ABORT is pressed.
Let me know how you get on
-(e)
I tried the mastering tool I mentioned. Unfortunately, in the resulting TAP file there are extremely long pauses in between turbo blocks. I mastered the same data onto a real tape and dumped it with MTAP for testing; in this case, the pauses are about 1 second each. This is a problem.
Other things I noticed:
- I got this a couple of times: https://drive.google.com/file/d/0Bzo...JjUzl5Ylk/view
- "Auto di finalizzazione" should be "Auto finalizza"
- While recording, the spinning character spins even when the motor is off.
- When you stop the recording to finalize it, it says "Aborted".
Can you give me a detailed run down of what is going on, or perhaps steps to replicate?
I'm assuming something like this is happening:
The turbo blocks are each read from disk. The fix that I made does not stop the recording, however the time between each section is now recorded, hence the long pause?
If this is the case, then the MOTOR signal would need to pause / unpause the recording which may be possible to do.
Hmm strange, I will try to duplicate, please let me know if you find a way to do so.
Hehehe, well that is Google Translate for you! Thanks for the update I will sort it out :).
Yes, perhaps we need to fix this as above.
Yep, known issue, I will will change that so it says complete if Auto Finalize is OFF.
-(e)
Pushed a version with fixed translation and stop message.
Still looking into the other stuff
-(e)
The strange string comes up when I press "Abort" in the "Select mode" menu. Then, if I press "Next" or "Previous", normal menu items appear.
