Best IDE Cable Solution for A4000
I want to run three IDE devices in my A4000 - master IDE HD, slave CF HD fitted to rear PCI slot, and an optical drive. Currently I have the motherboard IDE interface connected to the main HD, and then a Tandem IDE card in a Zorro slot connected to the optical drive. What's the best way to connect the third device (CF PCI) to my setup? I believe each IDE interface can handle 2 devices, logically I would run the two HDs off one cable but they are quite far apart separated by the daughter board, and I haven't seen any IDE cables with 2 connectors far enough apart to reach. But of course I have the same problem with the Tandem, as the optical drive is also on the opposite side from where I want to fit the CF!
So what should I do? Can you get IDE cables with two connectors 20+ cm apart? If not do I need to buy a third IDE cable and use an adapter to connect it to one of the other IDE cables (and if so which one?) I obviously want to keep cables to a minimum, and I believe the Tandem card is not bootable so ideally both HDs should be running off the same cable (I might install OS 3.5 on a partition of the CF just to play around with it.)
