2 Attachment(s)
BFG Tech GForce 9800GT 1GB PCI 2.0 GFX Card
As per the title, in excellent working order and boxed.
Box is a little bit tatty as you can see by the picture. Had to use stock photo of the card as it was in my other PC being benchmarked at the time of posting this. :D
45 GBP + postage
Techie Stuff
GPUNVIDIA® GeForce® 9800
GTCore Clock 625MHz (vs. 600MHz standard)
Shader Clock1566MHz (vs. 1500MHz standard)
Shader Model 4.0
Texture Fill Rate 35.0 Billion/sec.
Stream Processors 112
Video Memory 1GB (1024MB)
Memory Type GDDR3
Memory Data Rate 1800MHz
Memory Interface 256-bit
Memory Bandwidth 57.6GB/sec.
Bus Type PCI Express® 2.0
Display Connectors 2 Dual-Link DVI-I, HDTV + TV Out
RAMDACs Dual 400MHz
Multiple Monitor Support Yes
HDCP Capable Yes, Dual link (Requires other compatible components which are HDCP capable. Designed to meet the output protection management (HDCP) and security specifications of the Blu-ray Disc and HD DVD formats, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays)
HDMI™ Capable Yes (Requires adapter and audio cable, sold separately)
NVIDIA® SLI® Support Yes, 2-Way
