4 Attachment(s)
A600 Motherboard
I have to reduce my extensive collection so am starting now.
I have various motherboards , this A600 is fully recapped with tantalum caps and 4 new through hole caps.
And I have sourced the `non polar` capacitors for the audio output behind the k/board connector so its as should be :)
ROM is Ver 37.300 so IDE port is available
I have done two discrete repairs and the only problem is with the delay line circuit which gives a ghosting picture when the CV output is used , the RGB picture is perfect, if you need a RGB to scart lead I can supply one for £10 so add to total if required
This board will last another 20 years :)
PCMCIA working and Board has been been cleaned and looks excellent cosmetically.
asking £30 (ppal as gift) + post ( £9 in the UK)
Attachment 79964Attachment 79965Attachment 79967Attachment 79966
replied in PM to cromwell
Interested if Cromwell drops out.
Maybe it's too late but also interested. 3rd in line...
Payment received, thank you :)
Posted and Tracking details forwarded
Item received. Though no life from it as of yet, just a black screen. Will test some more
???????????????? this was tested fully prior to being packaged.
Has it been damaged ?
Nope, no signs of damage. Package was intact and so on. Tested rgb output and rca output, seems to receive some signal to monitor, but no more than a black screen.
