I am going to fit a gotek floppy emulator to my Amiga 600. When running games I take it I won't suffer the same memory limitations of using whdload. Will all games run without problem on a bog standard 600 ?
I guess it should work exactly like a disk drive, so I don't think there will be any problems with a stock Amiga.
Ok. That's good news. Needing more memory is a pain.
It just emulates a real floppy drive is if the game ram on the A600 for an original floppy drive, then it will run from the Gotek drive. Mine works perfectly with my A600.
To get the drive to fit properly in the original floppy drive bay you do need to modify the case otherwise the Gotek is too far inside the case, making it hard to see the LCD numbers or access the buttons. Alternatively you could pass a cable out through the floppy drive slot and mount the drive externally (if you didn't want to modify/damage the case).
Also, remember that many games are not OS2.x compatible. Use softkick disc to temporary go to OS1.x. Though, there will still be some games that won't work using this method.
One solution to avoid cutting the case is to strip Gotek's casing and customise it. This requires some patience and skill.
Is needing more memory really that much of a pain? Kipper2k's 4 MB boards are not much more than a Gotek, plus doesn't harm your shell. And with whdload, more games will likely work on your A600 than booting them from the Gotek (as many games originally aren't that compatible with ESC, >512k RAM and kick >1.2, all addressed and fixed by the various whdload slaves).
IMHO Gotek is better and cheaper alternative, possibly even easier to use. I've only paid 15 EUR for Gotek and 2 EUR for programmer. Contrast this to the cost of FAST memory + secondary memory (CF card and IDE adapter).
Gotek has much bigger software library due to the fact that quite a lot of software has not been WHDLoad patched. That being said, WHDLoad really stands out when it comes to fast floppy loading times. Thus, I prefer using both. :)
Yeah, +1 for both. But if price is an issue I'd say it depends... Is there already a harddrive? If so, get a FAST expansion.
About the software library, I'd say you have more games working on an A600 with whdload than from floppy, because of compatibility issues. I have no statistics on it, but I know there are loads and loads of working slaves and quite many which won't load on an A600 from floppy. And you got other features with whdload such as bug fixes (hint: Moonstone).
I've played hundreds of ADFs on A600 with Gotek and found only 2 games not working with softkick (Double Dragon and Lost Patrol, though I have found working versions). What I am really missing with WHDLoad is the lack of trainers and cracktros before the game. :)
For cracktros etc floppy/gotek is mandatory. I was just talking about games. :) Now I think this thread is stuffed with all opinions and facts needed for making the right decision. :)
