GBA1000 68060 Turbocard build project
Welcome to the GBA1000 68060 Turbocard build thread. This time I'll be building a GBA1000 68060 Turbocard (GBA1K-TK-02) for GBA1000 rev1-rev4 motherboards.
Without further ado, let's get started. Here is the empty turbocard PCB that needs a few components.
https://t.imgbox.com/OcpKSBeH.jpg
The assembly is best to start by soldering the small pitched (0.5mm) TQFP chips first.
https://t.imgbox.com/dpK3NEUC.jpg
Some are in the belief that these chips are very difficult to solder. Actually with the right tools and technique, soldering the TQFPs is really trivial. All you need is a soldering iron with bevel or chisel tip, some solder and flux.
https://t.imgbox.com/zCZdcWNJ.jpg
The soldering technique I'm using is called sweeping. First the chip needs to be anchored to the PCB by soldering a few pins in place. I anchored the chip from two sides. After anchoring a side, it's best to check that the pins are still perfectly aligned and if not, realign the chip before progressing.
https://t.imgbox.com/eEGrlnJ3.jpg
When the chip is in place, the chip is soldered one side at the time by sweeping. To do this, add some flux to the pins of an unsoldered side and add some solder to the bevel tip. Then place the tip on the corner of the chip and sweep the tip across the pins to the another corner. Each pin of the side should be nicely tinned with a single sweep.
https://t.imgbox.com/QOWrx7cB.jpg
After a few sweeps the chip was soldered in place.
https://t.imgbox.com/93FfG8DF.jpg
Another suitable technique is to solder the pins by point to point. First flux the pins, then add some solder to the tip and just touch the pins by sliding the tip on the PCB towards the pins. With this technique you are soldering a few pins at the time, depending on how wide the tip is.
Here's a good video showing these techniques in action: https://www.youtube.com/watch?v=5uiroWBkdFY
Sweeping technique is shown at 1:41 and one version of point to point at 1:20.
While I was in momentum I put the rest of the TQFPs and also the memory chips in place.
https://t.imgbox.com/RMxNCQ4q.jpg
The rest of the chips were easier to solder. I continued the assembly by populating the capacitors and resistor networks of the right-hand side.
https://t.imgbox.com/FR00MGMp.jpg https://t.imgbox.com/HKvzjE9B.jpg
The assembly is halfway finished, the more populated left-hand side is still to be done. And the bottom side with the small 0603 package capacitors (1.6mm x 0.8mm).
https://t.imgbox.com/pwPvNMVl.jpg
Update 27.12.2014:
I began filling the left-hand side by first soldering the smaller capacitors and resistors around the big coils (L1, L2). Then I added the bigger 100uF tantalum capacitors and the rest of the smaller components (diodes, ICs, oscillator). Finally I put down the big coils.
https://t.imgbox.com/qTyiBXXf.jpg
The legs of the JTAG connector filled the pads pretty much completely, so I used a bit different approach to solder the connector. I put some solder paste on the pads, placed the connector in place and heated the legs with a soldering iron.
https://t.imgbox.com/umLZkWfa.jpg https://t.imgbox.com/zAkHY9Zu.jpg
Only a few more components were left to be put in place, such as the 68060 CPU socket and the 68030 connector. I had a proper socket for the 68060 CPU, the 68030 connector was crafted from round pin strips.
https://t.imgbox.com/kUQeHjZZ.jpg https://t.imgbox.com/PFuXJFtP.jpg https://t.imgbox.com/e1kBJ2Ik.jpg
The assembly is now finished. Next it's time to program the Xilinx chips and test the board.
Update 28.12.2014:
I chose to program the Xilinx chips onboard using JTAG. JTAG provides a handy way to reprogram the chips if needed. No need to desolder the chips, reprogram them and solder back.
Here is the JTAG pinout and the JTAG programmer connected to the turbocard.
https://t.imgbox.com/c8X2eeR4.jpg https://t.imgbox.com/EBkcbHGy.jpg
The chips are programmed using the Xilinx WebPACK's iMPACT software. The WebPACK is freely downloadable from the Xilinx website.
Plug the JTAG programmer to the computer and start iMPACT. Let the software create a new project.
https://t.imgbox.com/qWaNySgz.jpg
Let iMPACT automatically detect the Xilinx chips of the turbocard by choosing "Automatically connect to a cable and identify Boundary-Scan chain".
After the scan iMPACT should have found three programmable chips (XC9572XL and two XC95144XLs). Assign the jedec files (*.jed) for each chip as shown below. The jedec files can be found from the a1k_tk.zip archive found from Georg Braun's website.
https://t.imgbox.com/e48WobKm.jpg
The default settings how to program the chips are fine.
https://t.imgbox.com/zpxKsCbu.jpg
I programmed the chips by first selecting all chips with Select all button. Then started the programming by clicking Program. After a few moments iMPACT reported that the programming had succeeded.
https://t.imgbox.com/3U480rl0.jpg https://t.imgbox.com/kI0OgJ8O.jpg https://t.imgbox.com/va7WchaC.jpg
The 68060 turbocard is now ready to be plugged to the GBA1000 motherboard. Almost... First the Boot ROM of the motherboard must be programmed with a boot code for the 68060 turbocard. The turbocard does not start without the boot code. The 68060 boot code can be found from the GBA1K_TK060.zip archive from Georg Braun's website.
The programming is done using the onboard 68030 processor of the motherboard. First I removed the S5 jumper from the motherboard so the Boot ROM could be programmed. Then I started the computer and erased the Boot ROM with erase_flash command and programmed a new boot code with execute gb_a1k_060_ram.
https://t.imgbox.com/2ks32yG7.jpg
After that I turned off the computer and put the S5 jumper back to enable the Boot ROM. The 68030 processor was replaced with the turbocard. Also the 50MHz oscillator was removed from the motherboard, as the turbocard is now handling the CPU clock signal.
https://t.imgbox.com/pWjqqmNl.jpg
With excitement the computer was turned on. Did the turbocard work? Yes, I was greeted with the 68060 boot intro.
https://t.imgbox.com/JnDBkKEi.jpg
Here are a couple of benchmarks...
https://t.imgbox.com/nPM7hdOW.jpg https://t.imgbox.com/g77X49Zj.jpg https://t.imgbox.com/8x1Fk7MU.jpg
I used a MC68060RC50 rev6 71E41J processor with the turbocard.
The jedec files found from the archive are set to run the 68060 with 100MHz clock speed. If you have a 68060 CPU that can't handle 100MHz, you have to modify the ABEL program codes and compile new jedec files from the modified ABEL files. The ABELs are also found from the same archive. I have tested the turbocard also with 50MHz clock speed.
