Hi guys wondering does anyone know how to get this pass through to work without the software. If workbench loads the piccollo will allow the pass through ok untill u have to boot into a game or a workbench disc.
Thanks al
Thanks al
Do you have a scan doubler or does your monitor sync to AGA? The Piccolo pass through shouldn't need any software but it doesn't double the scan rate.
Hi
Yeah I have the Indi Mk2 I had taken it that once the machine booted it would decide which output it need and just push it through but for some reason it does'nt
Yeah for some reason the passthrough does not work
So you say the passthrough works when workbench loads but not with a game or booting off something else. But when workbench does load and the passthrough is working, it does display the Indivision output correctly, it passes through just fine? Did you try the passthrough from the normal rgb port into the Piccolo?
to be honest it has my head screwed up if someone has a step by step guide that would help me loads I am using cybergraphics with the card and the indi as well
Thanks guys
AL
It should just work. Hold down the left and right mouse buttons on boot and see if the Piccolo passes through the native amiga video from the early startup menu. The piccolo pass through input has a 9 pin connector, are you sure the cable that goes from the 15 pin VGA output from the indivision to the 9 pin input on the Piccolo is correct?
OK bit of an update tried it via the Amba output works perfect but with the Indi it fails to work any idea's
