Quote:
If you follow the trace. From the pad, down the hole, other side of the board, and straight to the one of the Angus pins..
This is wrong. It's the pad that's closest to the Agnus socket that should be connected to pin #41 and only that. The other, away from the socket, pad should not be connected to any Agnus pin, it should be connected to ground (it already is). Undo the connection to that other Agnus pin because now you're incorrectly grounding an Agnus pin!
Quote:
You see I bought the board from the UK, so it's PAL build.. If you bridge the pads, then the bottom track joins the other pad track (That goes to the Angus too)
Here's a photo with the whereabouts of JP4.
