Seeing this, is just making me look forward to the day I receive mine, def a case of quality over quantity for sure now.
Card received 30/01/2016. Tested quickly yesterday : it works well! Thank you Majsta and the Apollo team, you're amazing :)
Does the vampire cover the ide header in anyway? looks like its going to be tight around there.
No, ide header are not covered at all. Here you can see a IDE cf adapteur that has still another connecter on the right from ide header... So, no collision problem at all with the A600 ide headers...
EDIT : Vampire sd car reader onboard is still not active. We have to use the A600 IDE.
mine is similar to this.
http://www.ebay.co.uk/itm/Amiga-1200...-/131640631665
the ribbon cable comes directly out (to the right) towards the vampire. just wondering if there will be a problem with the cable itself pushing into it as well as having the CF card resting on top of the vampire?
I think you will have no problem, there is enough place. Plus, the Vampire is secured with 2 screws, one on each side of the board. It's well stable.
Kickstart uploaded.
Wer ist bielefelder
Gesendet von meinem GT-I9505 mit Tapatalk
