This is a known problem with the silver core
Better use http://www.apollo-core.com/ for problems and bugs with the vampire 600 V2
@sordan that is not normal soft reset works just fine. On vampire you can check Q1 and Q2 and look that maybe soldering is not done properly there.
Than we all have to check this.
sordan, sardine and me. We all have the same problem. And we all have to check the solder points? Really?
Here`s Sardines fred:
http://www.amibay.com/showthread.php...-My-Vampire-V2
Ah no then it must be something else :P I ll take a look, if it is bug in chip controller it will be fixed in next revision. Why I said about those components to check soldering is because I did test this on each board and soft reset worked just fine on my side, that's why it was strange.
It works. But not every time. So i thought the problem is the silver core.
Indeed. 2 of 50 soft reset I did went fine. 48 of them freeze system with red screen.
Majsta, could you by any chance update the list on first page regarding the info about who has uploaded their kickstart so that those who uploaded and aren't "on the list" yet, don't have to wonder if they did something wrong.
Thanx a ton
Just take a look at the FTP server for the kickstart images. ;)
Hi, it is still possible to order the card ?
Yes. From Kippa2k.com . send an email.
