Yep. These are being soldered and shipped by majsta alone (I believe kipper2k is soldering for his orders) so anything more than 2 a week is good going. I am not holding my breath, but this year would be nice.
Hi all, I must say that lately I didn't had too much time to solder but this will change. As you probably know I m working on multiple projects in parallel and that takes a lot of time. Same time I need to solder and work on other models of Vampire. Situation now is that I can solder one Vampire card in half an hour but problem is to find that half an hour :) I know that you are impatient but more and more good news will come when all settle.
I need a very slim hdmi (to go inside the A600) and a standard size one for the monitor. The one he shows seems to be standard on both ends? Does he use an adapter? Not very clear.
i think mini hdmi or micro hdmi might of fitted better on vampire 2 has people reporting when connect cable pops the vampire off the cpu has tight fit.
That has more to do with the dimension and stiffness of the cable and less than of the connector being used. I found a thin and rather flexible HDMI cable which I think should be suitable. I guess I'll find out when I receive my board. Also, the cable could be tied to something in the correct position to relieve any stress from the Vampire board.
Which one does the Vampire have? Micro or mini? I would like to buy before hand. Any links to the best hdmi cable (from people who already have their boards) would be great.
Cheers
I have my Vamp and have tried a few cables but need a male to female so I can put the female end on a board and put it where the rf module was ,this is ordered now
http://www.ebay.co.uk/itm/1119132208...%3AMEBIDX%3AIT
On my side I will try to build something with this extension:
https://www.ebay.com.au/ulk/itm/201237722776
Maybe will use the extension door with a 3D printed model...
