thanks for reply also in pm.
installation of ovr & int2 is ok.
it works perfecly.
items delivered yesterday
it is correct the installation of the v402 on a500+ like this picture ?
Attachment 124151
ovr & int2 are ok ?
thanks
it works perfecly.
Attachment 124151
ovr & int2 are ok ?
thanks
Declaring Interest:
1x v402 with CF adapter
1x 8MB board
1x riser socket
The IDE and RAM boards together works great and makes WHDLoad possible. Really slick!
Anyone using the 402 IDE board and the 8MB board together in a 500? When stacked, it's a few mm too tall and the keyboard no longer lays flat in the case. Does the riser board move the stack enough to avoid this? Any suggestions?
BTW, while the 8MB board fits an NTSC 1000, the stacked combination does not. It rubs up against the floppy drive. It needs an offset board like the Kipper2k boards.
Interested in 8meg ram expansion and ide adapter v402 with cf adapter for a500.
Do i need a riser between the adapters?
how much in total with shipping to the netherlnads
I found out that the riser board 'consumes' the headroom it makes, still missing a few mm and touching the keyboard. (A500 case and keyboard, a500+ mainboard)
The riser card might barely work if the ram board were soldered directly to it, saving a socket's height.
So for (standard case) A500, 1000, there is not enough space to fit. I'm going to try with amiga 2000.
During the week i should be getting new ram pcbs that would not need a separator socket.
It should be possible to build an external combination with the external dip-64 adapter to a500 side connector.
Sent a regular e-mail with interested in one CPU offset adapter, and one IDE68K, as they may be available, USA. e-mail matches my name here.
Thanks.
Declaring Interest:
Declaring interest in:
1x 8MB board
1x riser socket
Will send PM.
After some shipping delays, some new pcb for ram will arrive finally tomorrow.
Will reply to interested then.
Blank pcb:s for 68000 offset 5€/pce (5pcs)
4 amiga ps/2 mouse adapters, 15€
Header to connect to other mouse port for wheel
