Well, I think that adapter does not need modification. Just plug it in. (leaving that 4-pin power header unconnected)
Are there any of the ide68k (or cfide) adapters left? I'm interested in one.
Cheers,
Thomas
About 8 pcs v402 adapters for sale.
Hi mkl, i'm interested in one v402 ide68k adapter.
sending you pm.
also interested in v402 ide68k adapter.
Not sure if this was asked or discussed already, but how do you go about making the FLOPPY LED light up when Hard Disc access is on?
PM sent.
Payment sent.
Thank you!
Payment sent
PM sent. :unsure:
I thought id fixed my IDE68k speed issues but I clearly havent, even with PFS3 installed both my 4GB CF cards are dead slow - Im getting 21,000bytes per second transfer from my Floppy drive and 5,500bytes per second transfer from my CF Cards. I've even installed IDEFix97 and it hasnt made any real difference and either does boosting the buffer sizes. :(
CF Card:
http://dl.dropbox.com/u/71121999/Ami...2018.05.31.jpg
Floppy Disk:
http://dl.dropbox.com/u/71121999/Ami...2018.55.33.jpg
Anyone got any idea's?
payment sent. thx in advance! :)
Yes I think it is. Unless everyone wants to start another thread for troubleshooting and questions for this particular adaptor.
Agreed, dont see why the thread cant be for sales and service - only issue is Mika seems to ignore most posts with issues. :(
---------- Post added at 08:43 ---------- Previous post was at 08:41 ----------
Yeah im not sure what the issue is but it was far far worse with FFS than PFS3 and I dont see anyone else reporting the same issues.
I have a replacement Rev8a board coming (have been using a Rev6a) and if the issue continues I'm calling HW fault.
Hi, check /int2 and /ovr connections, see a previous message in thread a while back, where that was the issue. V401 and v402 connections differ.
---------- Post added at 08:17 ---------- Previous post was at 07:54 ----------
Try and connect secondary LED+ signal to pin 8 of keyboard header connector (in case of v401/v402 and Amiga 500)
Or connect LED- to a 4k7 resistor and the other end to base of Q503 transistor on a500 (reference: rev5 schematic). Btw. To find which transistor pin is base, note that R504 is 4k7 the 'original' resistor for Q503 base drive and it's other end connects to _MTR0, pin 6 on U38 74LS38.
Hi Mika, Mines a v402 and the /int2 and ovr connections work fine - the leads are short and if they are around the wrong way or disconnected I have no IDE at all.
Btw, My unit only has pins on the secondary connectors.
http://dl.dropbox.com/u/71121999/Ami...2019.36.47.jpg
EDIT: a few folks have suggested i get an el cheapo 1GB card and try that so I'll post back when the one i just ordered shows up.
Try connecting /int2 to "primary" /int2 output.
Some cpld's were programmed with code revision where secondary wasn't working.
Slowness can be because Cf drive doesn't alert the ide driver by interrupt once it's ready to transfer data. I imagine that the driver would wake up because of other device is using /int2, maybe the other Cia chip.
Does the led shine even dimly? The positive output may only give a few mA of current.
I haven't tried these led hacks yet myself.
---------- Post added at 08:32 ---------- Previous post was at 08:27 ----------
About A1000: does the metal shield of floppy come nearly too close the ide header?
anyone know of any issues with using this IDE adapter with a LUCAS 020 accelerator board ?
http://imageshack.us/a/img839/8387/imageriq.jpg
Payment sent. Thanks Mike :-)
NOTE
Previously i thought that rev1 cpld code was where 2nd /ovr works, and 2nd /int2 not.
It now seems that 2nd /int2 doesn't work on rev0 cpld either.
And on rev1, also even 2nd /ovr, or 2nd led outputs won't work.
Testing rev0 and rev1 alternately, on one and same v402 adapter.
---------- Post added at 22:02 ---------- Previous post was at 21:57 ----------
a thought, A500+ gary might have difference (in need of /ovr) vs a500 (????) - or not.
---------- Post added at 22:11 ---------- Previous post was at 22:02 ----------
:Doh:
---------- Post added at 22:20 ---------- Previous post was at 22:11 ----------
Recommended is not to use 2nd outputs if they're not working.
Also /ovr should connect to primary output.
Led hack: 4k7 resistor from primary led- to transistor base and check corresponding mainboard revision schematic. (such as 5-something, 6smthng,a500+)
---------- Post added at 22:27 ---------- Previous post was at 22:20 ----------
:Doh::
ide-adapter arrived yesterday and after a bit testing it works great.
Thanks Mika, feedback left
Got mine today! thank you very much Mika. Feedback left.
Now... the installation part.:blink:
Who all have installed this in an A500+? Did you have a clearance issue?
Also who all have got the LED hack working? What did you do to get it to work?
Installation done on my A1K using Kickstart 3.1 under TwinKick and it works great!
Thank you very much.
has anyone used this with a djbase kick start print and a K 1.3 in an amiga 1000.
I get my cf under 1.3 not booted.
I have maybe a mount and scsi recognition problem.
under 3.1 works well I do have a scsi in my 1.3 with version I see though
got mine today just in time for the weekend:D
thanks Mika:thumbsup:
Hi MKL,
I am interested in one of these for a CDTV, to drive a CF card.
-I already have 2.30 CDTV custom roms and also a KS 1.3 / 3.1 rom switcher installed.
Can you let me know if they are suitable?
Regards,
Stu.
I'm also intrested in 2 boards fully build and tested, sending a pm.
Has anyone tried an IDE-Fix '97 or equivalent board with this? Interested to know if the secondary IDE channel is recognised.
Cheers
---------- Post added at 17:40 ---------- Previous post was at 17:37 ----------
Interested in one A500 IDE controller.
Sending PM
Yes, with the IDEFix Software I can use a CF-Card and CD-Rom together with the ide68k.
Cheers,
Thomas
Excellent, thanks! This is exactly what I want to do. :thumbsup:Quote:
Cheers
No, nothing special. CD Rom (24x) is slave.
I've read before about CF being incompatible with CD-drives when using some drivers (idefix?) I think in that case IDE hard disk+CD should work.
link: http://eab.abime.net/showthread.php?t=61666
