I'm after a working CPU for my A2630.
Any offers?
Any offers?
Erm...I really don't know if I can use it on my A2630. Anyone knows it?
It takes a PGA CPU right? So it should be able to down clock to 25? Or maybe you can change the crystal and run it at 40, but I'd wait for the tecnical genious' to confirm lol :D
http://www.amiga-hardware.com/showha...cgi?HARDID=165
One of these has the black plastic type CPU on...
Steve.
Again: all the PGA 68030 are the same!
Does not matter if you install a 25, 33, 40 or 50MHz mask unit, since internally they are the same.
Use the one you can grab.
@Jon Hare,
I've found a cheap A1200 case on Ebay but if you still need the CPU you can have it for the cost of P&P
Steve.
Thanks for the comments, guys! :thumbsup:
Well, if I can use this CPU and it won't cause any problems if it's downclocked to 25Mhz with the common OSC I'd like to buy this from you, Steve!
As I say I'm not 100% sure but from reading the thred it sounds like it will be just fine.
I'll drop you a PM and we can go from there.
Steve.
Payment sent :thumbsup:
