Revival of an Spectravideo 728
I recently got a Spectravideo 728 MSX from the Swedish cousin of the other bay. When I first tried it out, it powered up but I could not get a screen, not a proper one at least. The screen was light blue but there wasn't any basic prompt on darker blue. From time to time there were errant horizontal streaks, where I could see hints of the white letters of the basic prompt. I opened it up but didn't see anything out of the ordinary.
Later on, I tried to keep it running for a longer period of time to see, if warming up would make any difference. To my surprise, after about 10 minutes, the screen went blank and the power led died. First I thought it was the PSU but trying with another unit didn't make any difference. Both PSUs appeared to be working, when I tried them in my Spectravideo 328.
Now a bit of the anatomy of the 728. It consists of two boards: the main motherboard that has the main ICs and a video decoder/power supply board. The latter rectifies and regulates power to the main board as the "PSU" is a simple transformer, supplying only AC.
After the 728 went completely blank, I first measured the voltages coming to main motherboard. There were none, so something has died on the video/power board. It has few ICs for the video decoding but mostly just capacitors, transistors, resistors and diodes. I'll post some pictures later.
Now, if we think the power supply as a single entity, what is the first thing to check or change, when PSU stops supplyin DC? I measured the regulators and I could get voltages from all three at first but two gave about 1 V and one of those stopped giving any voltage.
I could really use some help from you HW gurus to get this thing up and running again.
