Finally setting up my BPPC system, having some problems
Hi
I've finally found the time to start & setup my BPPC+BVISION system, but (as expected) I've run into a few problems, both HW & SW.
I'll start with SW, as its more pressing at the moment.
My goal is to first get a stable OS3.9 AGA060 system running, then add the RTG & PPC stuff (CGX4, WarpUP, Warp3D).
This is my current setup:
Desktop A1200 rev 2B (my rev 1D4 doesnt like the BPPC at all, even after a timing fix) with KS3.0, 9.4GB HDD, BPPC w/128MB ram, BVISION.
Its driven by a 250W ATX power supply.
My first test was to use an HDD with CWB3.0 on it, with added 68040/060 libs.
This setup didnt boot (GURU), I had to disable SetPatch to make it boot.
It ran fine, but each time I've ran a demo using WHDLoad, I got a red screen after soft reboot.
A few days ago I prepared an HDD with CWB3.9 on it, with BB1,2,3 and using BlizKick to kick KS3.1 & the modules required by BB3 & a few from the BB2 ROM update.
This is currently the beginning of my Startup-Sequence:
c:BlizKick KICKFILE devs:rom_v45.57 EXTRESBUF=500000 MODULE exec.library bootmenu L:FastFileSystem L:RAM-Handler console.device L:Shell-Seg DEVS:scsi.device LIBS:icon.library LIBS:workbench.library
c:SetPatch NOROMUPDATE QUIET
I had to use EXTRESBUF of 500000, any lower value & BlizKick cried about not having enough memory to load workbench.library.
Anyway, the system boots now, but just before WB loads there's a requester with "Intuition is trying to close..." (It disappears so quickly I wasnt able to read it all!).
After that WB loads ok & seems fine, I was able to run a few 060 demos without issues.
The problem is soft-reboots, I get a red screen & flashing power led (endless reboot loop?) each & every time, so my only option is to turn off the machine.
I really dont know where to start debugging this, any help would be greatly appreciated! :bowdown:
