I have this A4000D which I bought a while back. It was cosmetically a bit beat up, but the innards looked good and I've since fixed it up shiny and new looking. It's been working fine since then. I recently acquired a Warp Engine which needed a little TLC. I fixed that up too, plopped it in the machine and it booted just fine. However, it wasn't recognizing memory in all the slots, so I took it out and worked on it some more. On reinserting it back into the machine, it would no longer boot. I assumed that I'd screwed the Warp Engine, tried a few things without luck and so put my 3640 back in. To my horror, it still wouldn't boot. So, I stripped it down, moved a few pieces around and eventually, it booted. So, I put the Warp Engine back in; no boot. Back to the 3640, no boot. Back to Warp Engine... boots! Put all the hardware back (HDD, CD, etc.)... no boot.
When it doesn't boot, it just sits there - black screen. No disk activity, nothing.
I'm suspecting that I have a broken trace or dry joint on the motherboard that's getting jiggled around (and probably being made worse) by all my experimenting.
Is it time to start hunting for a new mobo, or is this a problem that can be fixed?
