3 Attachment(s)
Simple Commodore 128 Upgrades
Hello fellow AmiBayers. :)
Today I decided to install a few mods in my Commodore 128 that I've had sitting around for a while. Here's what I installed:
The actual hardware installation on both of these was extremely easy because the Megabit ROM simply plugs into the open C128 expansion ROM socket and the JiffyDOS chips replace two ROMs on the board. The hardest part about these mods was modifying the case and heat shield.
I hoped I could find a way to mount the JiffyDOS switch without drilling into the case but, in the end, I decided to mount it above the cassette port. A drill at low speed made very little mess and a very nice, clean hole. Since I wanted to keep the heat shield, I had to do a little cutting.
There was a small bent-down part of the heat shield that would have touched the bottom of the JiffyDOS chip on the left side of the computer so I removed the bent down bit. The ROM-el chips sit much higher than standard ROMs so I bent the bits touching the chips up so they would touch properly. The majority of the rest of my time was spent cutting out the heat shield around the Megabit ROM since it's so big. :)
The last picture is the system all put back together with the 1541U-II, 64NIC+ and Final Cartridge III plugged into Jim Brain's X-Pander 3.
Ciao!
Heather
