7 Attachment(s)
KCS Power PC Board for A500
For sale is this KCS Power PC Board. Later revision V2 (P25.42) and supports harddrives & floppy drives. Included are 4 install & utilities disks & 2 user guides (Dutch language).
The battery was removed, but that doesn't affect the card's functionality. A new battery can easily be installed. This card can also be used as 512Kb Chip RAM for A500 or 1MB Chip RAM for A500+.
The card is tested en works 100%.
Techn. info:
A500:
Connects to the trapdoor connector
Zorro II (A2000):
The same A500 version is connected to a Zorro II adapter card
Power PC Board v2:
- NEC V30 @ 10 MHz processor
- supports HD controllers but a special driver is necessary
- software revision 2.90 supports the following HD controllers: A.L.F. (OMTI), A590 (OMTI, SCSI), Golem HD3000 (OMTI), Profex HD3000 (OMTI), Winner I (OMTI), F.S.E. (OMTI), Rex Datentechnik (OMTI), SupraDrive 500XP (SCSI), GVP A500+ (SCSI)
- much faster video emulation (CGA)
- revision 2 boards can be identified by board label "P25-42"
1 MB RAM:
- 704 kB free RAM in MGA/CGA mode
- 640 kB free RAM in EGA/VGA mode
- 200 kB extra memory for a reset proof MS-DOS RAM disk
- the RAM can be used by the Amiga as 512 kB Fast RAM and an additional 512 kB RAM disk
- the board can use the Amiga's Fast RAM (up to 8 MB) as PC memory
- does not multitask with the Amiga
- uses the Amiga internal serial port with up to 19200 bit/s
- uses the Amiga floppy controller and parallel port
video:
- up to 640×480 in 16 colours
- MGA 720×348
- CGA 640/320×200
- software emulated flicker-fixer in any PC interlace mode
- battery backed up clock
- emulated PC sound card
- not compatible with NTSC Amigas
I'm asking €40,- + shipping for this nice piece of Amiga hardware. :) Banktransfer (IBAN/BIC) only.
