I an interested about a cable, and an adapter:
6/ Cable (23pin conn and metal coated case with buffered Sync like Commodore VGA Adapter),
8/ Adapter Mini (23pin conn & case for perfect fit with every amiga including A4000D),
PM sent.
PM sent.
Payment received from Cvd.
Adapters for cromenco sent today.
Hi !
Declaring interest for one adapter :
3/ Adapter (metal coated case and 23pin conn with H/V or C-Sync Switch) - 16 €
PM on the way !
Payment received from Ludwig.
Adapter for Ludwig sent today.
Photo of the mini adapter in metal case added.
http://mujweb.cz/amiga1200/temp/avgamini-metal.jpg
Hi!
I am interested in:
6/ Cable (23pin conn and metal coated case with buffered Sync like Commodore VGA Adapter). White cable colour.
8/Adapter Mini (23pin conn) - plastic case, buffered version.
PM sent.
Payment received from Greg_k.
Hi !
PM on the way !
Hello!
I am interested in an adapter and cable.
8/ Adapter Mini (23pin conn) - plastic case, buffered version.
Sending PM with a question to make sure I am ordering the right thing. :)
Payment received from rmarkus and tastemakerChuck.
Interested! PM sent
Items for Greg_k and rmarkus sent today.
Payment received from jeriva.
Adapter was in the mail yesterday. Couldn't try it yet, but everything seems perfect ! Thank you very much !
Items for tastemakerChuck sent today.
Adapter and cable arrived at my mailbox yesterday - I checked them with Benq 912 and everything works fine. Thanks!
Miniadapters for jeriva sent today.
Hello, which cable do I need for my Amiga 1200 and BenQ BL702A? Please send me a PM, thank you.
PM sent to tom.jones. Check your inbox.
Payment from tom.jones for cable nr.5 received.
Hi, what do i need for amiga 500. I will PM you
@jobbez: PM replied.
im in US and need an A1200 RGB cable for a BenQ BL702A monitor. I have an Indivision but am not happy with it. Please let me know what cable I should get. It’s a PAL A1200 I just purchased from the (UK). Thanks
Could try the adapter with my OSSC at last. Works just fine, thank you very much !
Payment sent, thanks!
Payment received from shan2752.
Cables for tom.jones and shan2752 sent today.
Declaring interest in:
plus
EU shipping costs (registered priority delivery w. tracking):
for 1 adapter: 4 €
plus
4% PayPal fee 0.80 €
Am I right?
Kindly,
Mauro
Yes. PM sent.
Payment sent.
M.
Adapter for hiroshima sent today.
VGA adapters arrived today. All looks very good. Thank you!
Declaring interest in 1 black adapter (metal coated case and 23pin conn). Thanks!
Payment received from cl4ng3r.
Interested in an Adapter (metal coated case and 23pin conn with H/V or C-Sync Switch) - EU. Thanks!
Interested. I have a BenQ G2420HD monitor and a high quality vga cable. Which adapter do you recommend?
Shipped to Denmark.
Sent from my ONEPLUS A3003 using Tapatalk
Payment sent - many thanks!
Payment received from Mr_P and finnr.
Adapters for cl4ng3r, Mr_P and finnr sent today.
Hi guy,
I have a few questions about this adapter:
May I use this to connect an Amiga 500 to the OSSC VGA input using a VGA cable? Or it's better to use a DB23-to-SCART cable?
Second question: will this adapter work to connect the A500 to say a Commodore 1960 monitor with a HD-15 plug?
M.
Yes, you can connect to OSSC with it and it will work fine. You will possibly not notice big difference between SCART or VGA connection there. OSSC says SCART input goes thru a filter, and VGA input displays directly.
Yes you can connect to 1960 monitor with the adapter + vga cable.
So, VGA connection -picture quality wise- is recommended with the OSSC, isn't it?Quote:
Here, I need some clarification: buffered adapters are ONLY required with big box Amigas and not A500/600/1200? If so, why?Quote:
Many thanks!
M.
With VGA connection OSSC use separate hv sync, but requires good quality signal, as I said I see not much differece, but picture may look slightly sharper. I like I can connect 2 amigas thru OSSC, one by scart other by vga.
Regarding buffered thing, special circuitry in the Amiga video output can mistakenly identify a monitor as a genlock and thus cause problems (constant reboot loop / hang upon start that happens with bb amigas).
And the problem of incorrect identification of the monitor using unbuffered adapters like the one I ordered only happens with big box Amigas, right?
Also, when you say "special circuitry in the Amiga video output", are you referring to native OCS/OCS/AGA chipset or external video output?
M.
Yes & external video output.
