Interested in /8 - Mini adapter + Buffer. Sending PM
Interested in 6/ Cable (23pin conn and metal coated case with buffered Sync like Commodore VGA Adapter) 1x
Payment received from highpuff. PM sent to joshik.
PM Sent to a.mi.goun
Cables and adapters for easy32 and roc sent today.
Payment from joshik received.
Adapter for highpuff sent today.
Mini adapters with buffer arrived today and do not disappoint. Works better than a Gonbes gbs8200 (and doesn't require its own power supply). Fantastic work.
Interested. PM Sent.
Cable for joshik sent today.
Payment received from ambientmuesli.
Cable for ambientmuesli sent today.
Mods, if this is the wrong place for this, please remove.
I think we need to take the ACER v226hql off the list. I bought one based off recommendations I'd seen here and other forums. Mine was manufactured Sep 2018, and did not work. On looking at the info panel, it was reporting 16KHz Horizontal. I think the older models probably work, but there has been a model revision and the specs have changed. For now I'm back to using my Dell 2001FP, but having to set the picture every time is annoying.
I have an A1200 and a passive 23pin to VGA adapter.
Does anyone know of a current model LCD that they have purchased recently that supports 15KHz on the horizontal, in the 20inch + range?
I'm just looking for a simple plug it in and it works solution. Any recommendations? Is it indivision time? Are they simple?
Thanks,
J
I put a note about that Acer. Like I wrote before, manufacturers not always use the same components for the same model and there may be differences on Europe/US market so yes this may happen.
Received my buffered mini adapter today, thank you.
Will leave feedback ASAP:)
Interested in 6/ Cable (23pin conn and metal coated case with buffered Sync like Commodore VGA Adapter), PM sent
Payment sent - 30.5 Euro
Payment received from j_l_a.
My ASUS PB328Q works pretty well with the Amiga 1200. I'd never tried it before as it's a newish model. It also remembers the H and V position, I'm able to move the display to almost the middle of the screen.
I haven't figured out how to overscan yet, so there are black borders, but on a 32 inch monitor, not too big of a problem.
Cable for j_l_a sent today.
Interested in 8/ Adapter Mini (23pin conn & case for perfect fit with every amiga including A4000D) 16,5 € (silver metal coated case) +2 € (for buffered version)
Adapter for xyzzy sent last Friday with the other items.
Interested in 1/ Adapter (metal coated case and 23pin conn) - 13 €.
Payment received from ambientmuesli and treqie.
Items for ambientmuesli and treqie sent today.
Cable received, works great, thanks!
I try cable x genlock amiga mk2
male Female
I am interested in the following:
Option 2/ Adapter (metal coated case and 23pin conn with buffered Sync like Commodore VGA Adapter) - 15 € (black cable)
Option 8/ Adapter Mini (23pin conn & case for perfect fit with every amiga including A4000D) 16,5 € (silver metal coated case), option +2 € (for buffered version) – 17,5€
PM sent for shipping total.
Payment from Teps71 received.
Adapters for Teps71 sent today.
I am interested in two of the adapters. The ones with the metal coated shell like the picture. not the cut ones...Do you still have some?
Best regards,
sjamaan
I am interested in 2 of the mini adapters...shipping to Japan...
Regards,
Sjamaan
Yes, still available. Sending PM.
Payment received from sjamaan.
Interest expressed in Vga adapted with switch.
Shipping to Paris France
Payment received from rebate.
I'm interested in option 6/ Cable (23pin conn and metal coated case with buffered Sync like Commodore VGA Adapter), for use with OSSC.
Shipping to UK.
** Money sent 10/01/2019
Payment received from i4000.
Adapters for sjamaan and rebate sent today.
Cable for i4000 sent today.
Declare interest in onf of 6/ Cable (23pin conn and metal coated case with buffered Sync like Commodore VGA Adapter) - 22,5 €
PM on the way
Payment sent.
Hello, I'm interested in either #5, #6, #7 or #8. I'm uising a NEC 1970NXP on an A500 and A1200. Which option is best for this setup?
Declaring interest. PM sent.
Payment received from golgotha.
Interested in a buffered adapter suitable for the A4000.
PMs exchanged, payment sent for a buffered A4000-compatible adapter.
Payment received from eteP.
Cable for golgotha sent today.
Cable for jimbob sent today.
