Declaring interest in one "number 6" cable with 'huge filters' option, shipping to UK.
Will PM to confirm details. Thanks
Payment received form rikbliz.
Items for cemi and cable for rikbliz sent today.
For cables I can also supply luxury Home Theatre branded High Quality cables for demanding users with metal and gold plated vga connectors, oxygen free copper conductors and huge ferrite (interference) filters for extra +11 €.
https://i.ibb.co/8XVDmN1/rgb-vga-cable-deluxe-hq-ht.jpg
To use these cables or adapters also with GBS 8200 video converter, its possible with the sync switch cable (adapter). This cable (adapter) work with both 15kHz monitors (HV sync) and GBS8200 converter (C-Sync). Newly I add a resistor on C-Sync as recommended for GBS8200.
Order received, thanks.
Awesome cables received, many thanks!!
Cable received, working well and happy with purchase, feedback left....
Feedbacks replied.
Also added Dell P2214Hb to the list of working monitors. Thanks ath768 for the report.
Interested in home theatre cable for Amiga 2000 with BenQ BL912.
Payment sent, with thanks.
Payment received from Scaff75.
Cable for Scaff75 sent today.
Payment received for Jield.
Interested in :
1xNum 8 (mini 23 pin adaptor, grey plastic + buffer)
1x3 (23 pin adaptor inc csync switch)
Posted to UK
Miniadapter for Jield sent yesterday.
Declaring interest in one number 6 cable with metal and gold plated VGA connectors and ferrite filers option. Shipping to Denmark.
1x
6/ Cable (23pin conn and metal coated case with buffered Sync like Commodore VGA Adapter) - 23 €
please :-)
Payment Done
Payment received from Einherje.
Declaring interest in 1x No. 2 buffered Adapter. Shipping to Germany.
Gesendet von meinem SM-G930F mit Tapatalk
Payment received from torsti76.
Declaring interest in (two) 2x NEW: 8/ Adapter Mini (23pin conn & case for perfect fit with every amiga including A4000D)
- Silver metal coated
- Buffered version for both.
Shipping to Australia and you already have PM from your other thread. I will send PM to confirm these 2 though. Thank you.
Cable for Einherje and adapter for torsti76 sent today.
Payment received from Lord.
Payment received from p_a_green29.
Cable for Lord and adapters for p_a_green29 sent today.
Added BENQ GL2023 to the 15kHz compatible monitors.
Arrived and working. Thanks!
Cables and adapters for Rakeim132 sent today.
Arrived and working. Thanks! Feedback will follow.
Tested on my NEC MultiSync EA192M in 640x480 (productivity screen mode):
Attachment 146573Attachment 146574Attachment 146575
Adapters for erique sent today.
declaring interest in rgb to vga cable to connect to benq702a , still want to check which is the best to buy. Shipping to ireland
Thanks for your interest. For BL702A you do not need buffered. You can choose a cable from the first post. Available is standard DELL branded cables, or more durable robust 8mm cables and even a luxury option with Home Theathre branded cable.
Payment received from petarku.
Adapter for petarku sent today.
Payment sent.
cable arrived , will test soon
Mini adapters received in Australia today.
Amazing quality.
I strongly recommend.
Will leave feedback tomorrow first thing. Cheers.
adapter tested , all working as expected ! As new here need to figure out how i leave feedback :)
Interested in a - 5/ Cable (23pin conn and metal coated case) please with shipping to the UK.
Payment received from SensibleMagos.
Cable for SensibleMagos sent today.
Could I declare interest on the following please: -
4x RGB to VGA cables with huge interference filters.
The cables would for use on 2x A1200, 1x A600, 1x CD32 and for a NEC EA190M Monitor or Samsung P2270HD, I have both and I know the cables will work with the NEC EA190M, but have a Samsung P2270HD which I was wanting to test.
I'd like the RGB end of the cables to have the correct sized casing with both screws present so that I could have the option of screwing the cable into the Amiga's should I want to.
I wasn't sure which of the options this was however or whether all of the casing do this, if that is the case I would like the metal casings on all the RGB cables.
On your other post I would also like to declare interest in the following: -
4x NEW2:Adapter with A600 compatible connector and USB mouse connector now available. Price is 23,5 € + shipping.
I have declared interest on the "Amiga PS2-Mouse MINIMALISTIC CABLE Adapter" thread also.
Payment sent for 4x RGB-VGA and 4x A600 USB mouse adapters.
Payment received from aeromaxx.
Cables and adapter for jerriva sent today.
Cables have arrived, and working wonderfully well, extremely well made thank you very much!
Hi I'm interested in
1 X Deluxe VGA Adapter (metal coated case and 23pin conn with H/V or C-Sync Switch) - 16 €
2 X Gotek pink UV-light glow cable (15 €) (cable length 45cm)
To Australia
Payment received from reptar.
Would it be possible to build a buffered cable with BNC connectors instead of VGA? Looking for a few for use with Sony PVM monitors asap.
