Boxed ACA-500 and ACA-1220
Sadly, I don't use these as I was supposed to. Both are a bit over a year old, and come with the original box and ACA-500 with manuals.
ACA-500 with case: 110 EUR
ACA-1220 ceramic 020 @ 20 Mhz and 128 MB RAM: 120 EUR
Both: 200 EUR
The deal is reserved for 24 hours to anyone that is looking for either board on the Wanted Hardware thread.
Prices do not include shipping costs and PayPal fees. To avoid PayPal's lousy conversion rate, I also accept USD and GBP.
I've played with these boards on various Amigas. ACA-500 sometimes booted to blue screen on one A500+ after initial power-up. It worked ok with three other A500s. I assume it was A500+ not ACA. The ACA-500 case is a bit broken in the inside, because I had to bend one side if I wanted to fit ACA-1220 inside. AmigaStore wanted to send me the replacement but I didn't want to bother them (kudos to their support). It really doesn't show. ACA-1220 wasn't recognized on one A1200 (meant for spares), however it worked on two A1200s and 4 A500s without a problem, and one A1200 occasionally crashed on some demos but otherwise worked perfectly fine (apps, games, diagnostics). I assume problematic A1200s needed timing fixes. Non-problematic A1200s are without these fixes and they work. I am confident these boards work perfectly, just some Amigas may have issues without fixes. Buy only if you accept this as I don't accept returns.
High def photos:
http://thebackarrow.com/share/aca500.jpg
http://thebackarrow.com/share/aca1220.jpg
You can see ACA-500 (not sure if ACA-1220 was also inside) running WHDLoaded games on A500 and A500+:
https://www.youtube.com/watch?v=8PUjvy_MNXs
