Amiga hackable PC floppy drive
NEC FD1231H - Was £8, then £7, then £6, then £4, now £3.50 +p&p
This is a PC HD drive which can be hacked to be made Amiga compatible. RKauer kindly describes the hack here: http://www.amiga.org/gallery/index.php?n=2180
The drive has no front bezel or plastic eject button, it just has a slightly yellowed plastic shutter. The eject mechanism works (tested by pushing the metal stump). I am not sure if this will line up with the standard Amiga floppy drive buttons, there may be other Amibayers out there who can testify to that. I have not tested the drive to see if it is fully working, but the last time it was used in a PC it worked fine.
