1 Attachment(s)
A500/600 Dual Kickstart Switcher - Assembled or Parts Kit
Designed for A2000 (Rev 6), A500 (Rev 6+) and A600.
Long reset (C-A-A) of 4 seconds or longer switches the Kickstart image.
The switch board sticks to the back of a 27C800 or 27C160 EPROM containing the multiple ROM images. I have available for sale:
1. Fully assembled & programmed (with your supplied ROM images!) - £10
2. Parts kits (PCB + components)
a. with no ROM - £2
b. with blank 27C160 ROM to program yourself - £3.50
c. with programmed 27C160 ROM (you must supply the ROM images to burn!) - £4
Postage for up to 5 items: £2 in the UK; £4 Worldwide. Tracked & insured is extra.
Attachment 106521
Assembly/installation instructions here: https://github.com/keirf/PCB-Project...cher/README.md
Assembly of kit requires moderate soldering expertise. The kits are cheap practice however. :lol:
For the fully assembled switcher you need to hook onto the reset line, either with a probe clip (pictured above) or by soldering (required on A600).
I understand it's for newer motherboards and won't work on a rev.4 Amiga 2000A (the one designed in Germany and based on the A1000), correct?
