Workbench CLI command
Hey guys
I am looking for away to open a GUI drawer with my programs from the shell command line. I stuck my Programs drawer a little deep into my HD, moving it now will be a pain as I had to set a few assigns for some. I have a program that allows me to add stuff to the right click workbench menus (wb 3.1) so Adding Programs to the top menu which will then open that drawer as gui would be great. So anyway to open a gui drawer (same drawer that opens as if you were clicking dh0: programs etc) from cli?
Thanks for any help
o Adding Programs to the top menu which will then open that drawer as gui would be great:
http://aminet.net/util/boot/ToolsDaemon21a.lha
Ok here is it, ther are updates for os 3.9
http://aminet.net/util/boot/ToolsDaemon22.lha
have fun
Hi
Thanks :) I already have that running, what I need is the command to actually open the GUI drawer. Anyone know what such a command would be? If my Programs was actually in dh0: a/b/programs drawer. Its not but thats just a rough idea of where it is that I need to open. For all I know just adding the location in the tools menu will do this, but not near the miggy at the moment to test that. I would not think it would work as easy as that though. Also want it to open drawers for WHDload games as in A-Z to the menu, but again would need to get the drawer open.
Cheers
I think Scalos has this feature .... but not sure about plain ol' Workbench.
If you're on OS 3.5 or 3.9, try looking at some of the utilities in the 'Contributions' drawer on the CD, there's some stuff in there and I think there's a command that does what you're after, but not entirely sure as I've not got the CDs to hand at the mo.
Thanks for the reply. may have to give up on this one, its just plain old 3.1 unless I could find something on aminet that adds the feature.... Hmmmmm
Of I go to do a search :)
Thanks again
The only other thing I can think of, is a utility called wbrun
I found this tucked away in some .lha archive ages ago and it was used to run the Commodore FORMAT command to display the GUI as opposed to treating it like a CLI program. It's a long shot, but AmiNet might have it kicking around.
Is there not some way of using Directory Opus to do this?
Hey
I found this:
http://de3.aminet.net/util/cli/cli2win.readme
Which says os3.5 or Opus. Now I wonder if I have to set opus to be the workbench replacement. What does it actually do when set as a replacement anyway? Just boots right into opus?
Cheers guys
Looks promising and it doesn't say that you need to use opus to replace your WB - maybe you need to have it running though. I think when you select it to replace WB it does just that but I've only ever used it for it's usefulness in the past - never to replace my WB.
Good luck :)
John
Useless message, as I don't have the answer, but...
Is this something you might be able to do with ARexx?
I never used it much, so I'm not sure...
desiv
