2 Attachment(s)
Cybervision 64/3D monitor switch
Offering a small run of custom monitor switches for Cybervision 64/3D cards. They're based on a project published on a1k.org a few years ago (not Ratte's famous design). The switch is mounted in the opening in the Cybervision card's slot bracket and connected to the graphics card using a short flat cable, just like Phase5's original scandoubler. Another flat cable goes to the Amiga's video output or a scandoubler/flickerfixer output. Power is supplied via either a Berg-style floppy power connector or a standard Molex connector.
The switch is controlled by the CV64/3D card just like the original scandoubler. A LED lights up when the graphics card output is active. Switching is instantaneous and without interference or ghosting since it uses a semi-modern bus switcher also used on old Voodoo cards.
I originally intended to make just one switch for my own card, but minimum order quantities gave me a surplus, which I sell to recoup my costs.
Asking 40 € per card, delivered in ESD box and with cables tailored to order. Payment as gift via Paypal or IBAN/Swift. Postage around 3€ worldwide without tracking.
Attachment 114798Attachment 114797
Questions and answers
Q: Is this a scandoubler?
A: No, it is only a monitor switch. You need either a scandoubler (such as the one built into the A3000) or a multisync screen.
Q: Can I use it with other graphics cards than Cybervision 64/3D?
A: Yes, by connecting a manual switch to the jumpers on the card and making sure you've got the correct cables. I have read that is has been used with a Cybervision PPC.
