A1200 SCART (yep, another one with 'issues')
Ok.
A1200 works great connected via RGB cable to a 1084, or via composite to anything with a composite input.
A500 works great connected via (either of) two RGB to SCART cables connected to any of my TV's, and also via RGB cable to the 1084.
A1200 will not display an image via either of the same RGB to SCART cables used by the A500, on any TV. The TV's I've tried will auto-switch to the SCART input when the Amiga is turned on, but all I get is a black screen and one flicker when I would expect workbench to show (I'm guessing it's the screen mode being initialised) - even the early boot menu can't be seen (so it's not a workbench prefs cockup).
I need a solution to this problem that does not involve buying more monitors or TV's - I've been through enough of them (both old CRT and new LCD and Plasma) to realise that it's not them that's the issue. I have got to get the A1200 displaying via RGB SCART as I want only a single monitor/tv solution for my retro game setup.
I'm currently trying to get all my retro stuff (which is all RGB SCART or VGA) displaying through a Samsung Syncmaster 710MP. So if anyone is using one of those with a SCART cable, I'd love to hear from you.
Please help!
