HxC Floppy Emulator + Custom Case + 1gb SD Card
Hi!
I've decided to draw a line under this project and pass this awesome peice of kit on...
I'm selling my HxC Floppy Emulator which I have mounted in a clear perspex case which has all the needed connectors to use as an external Floppy Drive on an Amiga as (DF1)
I'm including a 1gb SD Card to get your started and will make a CD of the software to convert ADF's or other systems Floppy Images.
All the info on the HxC can be found at the below link:
http://www.torlus.com/floppy/
And there are lots of pics in my project thread:
http://amibay.com/showpost.php?p=95093&postcount=16
The case is only held together with a few blobs of hot Glue so if you want only the HxC its easy for me to remove it.
I've got the front and rear peices of prespex pre cut of you want to finish the case.
I'm looking for £70 +P&P as a complete kit or if you just want the HxC I'll sell it for £60 +P&P
Thanks for looking,
Steve.
**Also listed on EAB***
