HDMI over ethernet. Has anyone tried this?
I know is possible to use ethernet to send HDMI to a tv. Has anyone tried this?
Any info on 4K over Ethernet?
My reason for investigating this is Sky Q. As you know only the main Q box can provide 4K. All satellite boxes supplying other TVs can only get standard HD. If however I could apply 4K over ethernet I could split the output from the main Q box to supply a second TV upstairs in the study. Obviously I would only receive the same on both TVs but a compromise could be a satellite box as well so it can be switched between living room 4K feed and local hd feed.
Any idea if that is possible?
Sent from my SM-G900F using Tapatalk
