Advice Needed On A Black 1200 Project
I've stripped apart this horrendously yellow A1200 case I had and have decided to use this over my white enclosures for my Black 1200 project. I've used what's called a plastic spray (normally used on car plastics as it works it's way into the plastic and will not wear off).
What i'd like to know is should I clear lacquer it when finished? I've got a lovely even matt finish on it ( as can be seen below) as it stands (both inside and out) but want to make sure it won't scratch resulting in me having to spray it again.
Any advice would be very much welcomed. TIA.
Also, I was wondering, if I fit in a 250gb ide 2 1/2 inch drive how easy would it be to transfer all of my files over from my 4gb CF card that sits in there right now?
http://img.photobucket.com/albums/v4...g?t=1285689926
